Help request 2002 stratus SE rear strut
Old Oct 10, 2011 | 11:38 PM
issakar's Avatar
issakar
Default Help request 2002 stratus SE rear strut
Hello,
So I already have a thread going about the strut mount being broken but I have run into a snare and am hoping for some advice. I am creating this thread specifically to call for help.
I have removed the old strut and the remnants of it. I tried installing the new monroe quick strut and I had to stretch the knuckle down far to make the bottom part of the strut align and fit over the knuckle. I mean once it was on I could not push down on the knuckle at all and the bottom bolt wouldnt line up right, the knuckle would need to have gone down further.
I also picked up the dorman replacement mount. I attached this to the old strut and tried replacing it and same issue, I couldn't get the strut over the knuckle.
I am not sure what to do at this pooint. I NEED to get this car on the road tomorrow. please any advice is more than greatly appreciated!
Regards,
Issakar
Old Oct 11, 2011 | 01:42 PM
issakar's Avatar
issakar
Just a bump on this to see if anyone knows. Do I need to adjust the lateral links to make it work perhaps?
Old Oct 11, 2011 | 06:48 PM
BillS's Avatar
BillS
try using a strong screwdriver to pry the strut upwards to line up holes, place between knuckle and bottom of strut and lift upwardsits a pain sometimes to get bolt in
Old Oct 12, 2011 | 10:42 AM
issakar's Avatar
issakar
HI, Thanks for the advice.
I ended up reusing the old strut since the strut itself wasnt bad, just the mount. After installing the new mount i did a comparison of the 2 parts and the quick strut was just about a quarter of an inch longer than the OE part. The hardest part of installing the OE part was finding 2 bolts to hold it on with.
I would still like to know what I would have to do to use the replacement part for my own knowledge but I'm just glad the car is back on the road.
Old Oct 12, 2011 | 06:53 PM
BillS's Avatar
BillS
the quick strut will work out of the box(have on my 04),once you get it on knuckle you have to compress spring a little by either lifting up underneath with a screwdriver(have to fight with it) or if you have a spring compressor you can put that on once strut is on knuckle and tighten a few turns to relieve pressure to get bolt in
