Which o2 for p0058-o2 sensor 2/2 heater circuit high
This code came up two weeks ago and has not gone away after 500 miles, so I assume it's here to stay until I replace an 02 sensor, but which one is it? The car is an 04 stratus sedan with the 2.7 with an AT. It's a quick fix, but not sure which sensor it is. Thanks-
Symptom List:
P0132-1/1 O2 SENSOR SHORTED TO VOLTAGE
P0138-1/2 O2 SENSOR SHORTED TO VOLTAGE
P0152-2/1 O2 SENSOR SHORTED TO VOLTAGE
P0158-2/2 O2 SENSOR SHORTED TO VOLTAGE
Test Note: All symptoms listed above are diagnosed using the same tests.
The title for the tests will be P0132-1/1 O2 SENSOR SHORTED
TO VOLTAGE.
When Monitored and Set Condition:
When Monitored: Engine running for 119 seconds. Battery voltage greater than 10 volts.
Coolant temperature above 80°C (176°F).
Set Condition: The Oxygen Sensor voltage is above 1.29 volts for 30 seconds. One trip
fault.
When Monitored: The engine running for 119 seconds. Battery voltage greater than 10
volts. Coolant temperature above 80°C (176°F).
Set Condition: The Oxygen Sensor voltage is above 1.29 volts for 30 seconds. Two trip
fault.
When Monitored: Battery voltage greater than 10 volts. Engine running for greater than
121 seconds. Coolant temperature above 80°C (176°F).
Set Condition: The Oxygen Sensor voltage is above 1.21 volts.
When Monitored: With battery voltage greater than 10 volts. Engine running for more
than 2 minutes. Coolant temperature above 80°C (176°F).
POSSIBLE CAUSES
O2 SENSOR BELOW 1.2 VOLTS
O2 SENSOR OPERATION
O2 SENSOR SIGNAL SHORTED TO VOLTAGE
O2 SENSOR SIGNAL OPEN
O2 SENSOR GROUND CIRCUIT OPEN
PCM
TO VOLTAGE.
fault.
fault.
POSSIBLE CAUSES
O2 SENSOR OPERATION
PCM
