Blend door in heater box.
Old Nov 3, 2011 | 06:13 PM
stratusr/t02's Avatar
stratusr/t02
Default Blend door in heater box.
Does anyone know were there is a diagram for the heater box on a 02 dodge stratus coupe.I am having problems with the blend door not working right have cold air on drivers side and warm air on passenger side thanks.
Old Nov 5, 2011 | 03:44 PM
Jack Avant's Avatar
Jack Avant
I have a 2002 Stratus SE and I found that the damper for the control that lets the heat in was on the passenger side. The motor adjust the amount of heat. I loosened up the screws that holds the actuator so that I could adjust by hand. My stratus gas a center **** that goes from blue to red and I do not know if the motor for the actuator is bad or the **** that sends the signal to the motor. I hated to rig mine this way but my wife needed heat. I am sure someone on this forum knows what to do but I could not get any responses after two post. I hope this helps. You do not need to remove the radio, just the panel under glovebox.
Old Nov 7, 2011 | 08:05 AM
stratusr/t02
Thumbs up
Thanks, I went to another web site and read what I needed to do.The heater core was bad stopped up on one side so I replaced it this week end and WHAT A JOB no wonder it would cost 1,000. to 1,500. to do this.I have heat now but thanks for your reply.
