Transmission Whine / Whining Trans
Old Nov 8, 2011 | 12:51 PM
Rocket67's Avatar
Rocket67
Default Transmission Whine / Whining Trans
2002 SE with 2.7L (Sedan)
Transmission whines when not in or out of the throttle. Ex. when excelerating there is no whine, when decelerating there is no whine. When in the middle, like neutral zone where the car is pretty much gliding or in 10% or less throttle I get a whine. Everything works really well, no slipping, shifts are crisp, just noisy. If I turn the radio on I don't even notice it but something tells me I should be paying attention. I did change the trans filter and 5 quarts of new fluid. The car has just under 78K miles so I doubt that it's going out, just wanted to see if this little bit of noise was normal for this model or signs of something approaching.
Old Nov 9, 2011 | 12:24 AM
master tech's Avatar
master tech
Site Moderator & Tech
You maybe hear the transfer gears. This was common problem back in the 1990"s. If it starts to get louder, then I would look into fixxing the noise.
Old Nov 11, 2011 | 04:50 PM
Rocket67's Avatar
Rocket67
Under 78K on it and the miles that were put on it were mostly long road kind of miles. Not sure what it is but doesn't seem to affect the performance. Will hope for the best, maybe just normal noise that I am just not used to. Had a 79 Camaro that did the same thing but it was the rear end. No issues, just like to make noise. Who knows....I guess if it breaks I will know what it is.
