Troubleshooting fuel system issues - Need Help
Old Dec 15, 2011 | 07:29 PM
gsimms's Avatar
gsimms
Default Troubleshooting fuel system issues - Need Help
Evening everyone,
I am new to the forum and have only posted one time previously, so let me say thanks for the responses last time and I am glad to be a member. This place rocks!
I have a 2003 Stratus 2.4L DOHC (Sedan)
I recently installed a new radiator and have been performing some other minor maintenance. I noticed an idling issue once I got the car running again after I replaced the radiator.
My initial thought was a a timing adjustment (I am a novice "mechanic" so forgive me if I sound dumb). After talking to a couple of mechanic friends, we determined that it was either a vacuum problem, dirty fuel injectors, or something very minor. Since then, I have done the following:
  • 2 treatments of fuel injector cleaner (Lucas brand)
  • cleaned the area around the throttle and air intake assembly (nothing major)
  • checked the air intake (air filter, etc.)
  • replaced the pcv hose that runs from the engine to the air intake assembly
I had a diagnostic ran on the car at Auto Zone and I received the following codes:
  • P0303
  • P0441
  • P0440
  • P0300
Based on this information, is there anyone who can help me troubleshoot the problem further? I really need help and I am very low on funds to try and have a local place do the work.
The fuel system seems to be working a little better, but I still have the Check Engine light on and when I am in Reverse or in idle, the car stutters terribly, sometimes even stalling out.
I would be very appreciative if any one out there can offer some suggestions or help me via the interweb troubleshoot the issue.
Old Dec 15, 2011 | 07:38 PM
gsimms's Avatar
gsimms
One thing I forgot to mention. When I said I cleaned the area around the throttle body and air intake assembly, I DID NOT clean inside the area where the valve door is. I was worried about messing up something until I got some more advice. Again, I am a NOVICE. Sorry, if I sound moronic.
Old Dec 15, 2011 | 09:00 PM
SpecialistBoicourt's Avatar
SpecialistBoicourt
303=cyl #3 misfire/ 300=random cyl misfire
if i remember correctly 441 & 440 r evaporative system codes
sounds to me like u have a vacuum leak sumwhere.
the ecm adjusts timing. u cant.
while the engine is idling, spray ether or carb cleaner around the engine, if the rpm's change, u've found yor leak.
Old Dec 15, 2011 | 09:20 PM
gsimms's Avatar
gsimms
Thanks for the response! Ill have to get some ether or carb cleaner in the morning. Probably a long shot, but would happen to know of any free resources where I could get a layout of the entire engine? I want to familiarize myself with everything.
What area should I be looking at that would most likely be where the leak is? A general area, if you will.
Yes, I am a nerd.
Old Dec 16, 2011 | 11:45 PM
steak59's Avatar
steak59
If it is a vacuum leak, you will have High idle, and smooth out when u rev the RPM.
Maybe u need a Tune up and possible a new Coil Pack.
or low fuel pressure, spray some Throttle body cleaner or Brake clean into the intake gentlely, see if it smooths out the engine.
If you have/can afford a cheap hand held scanner, I would recommend you to erase the Code, see which mis-fire codes return, and swap out the coil pack, see if code follows.
The Scanner that Autozone use, you can probably pick one up online for $25, or $35-50 from Advance auto, with all those Online discount coupons.
