P0156 Code for O2 Sensor on 2001 Dodge Stratus SE v6 Coupe
Old Dec 30, 2011 | 02:32 PM
mr_pleco's Avatar
mr_pleco
Default P0156 Code for O2 Sensor on 2001 Dodge Stratus SE v6 Coupe
I've got a P0156 code on my stratus, which is Bank 2 Sensor 2. I'm not a car guy so when I went to autozone, I learned that there's 3 different sensors that I can get. Generally, what is that sensor? Is it post/pre catalytic converter or is there a better description that I can use to make sure that I get the right part?
Old Dec 31, 2011 | 11:49 AM
BillS's Avatar
BillS
Sensor 2 is after converter(downstream) bank 2 is the bank with #2 cylinder,varies by which engine in car
Old Oct 26, 2012 | 05:28 PM
Jay6220's Avatar
Jay6220
New Member
2001 Stratus 3.0 A/T
I get the same code. P0156, car wont pass emissions test. I've replaced both the upstream and down stream sensor on bank two. I figured they both were old an probably getting lazy anyway. Any one have any suggestions. I have run out of ideas. When hooked to a scan tool I can see that the voltage from the sensor B2 B2 is 0 (v).
Old Oct 26, 2012 | 06:41 PM
BillS's Avatar
BillS
could be bad wiring to sensor, or it might be a loose ground not sure about coupes ,on sedans theres a ground strap by muffler could be loose, could be a problem with the Asd relay circuit ,bad pcm, or the sensor you bought was defective
