2004 Stratus driver side leaks Why?
should be 2 hoses on driverside 1 runs in the pillar between front door and window,other runs out back in rear quarter panel on a sedan here are basic instructions for a sedan, if diagrams don't show up right you can send me a private message with an email address and i'll try emailing to you(usualy diagrams act weird when i try posting here shows up as something entirely different then i posted
REMOVAL
for front or back
Drain any liquid from hose connection, if necessary.
Attach new drain hose to old hose with tape that is to be replaced.
Work the old hose back and forth to loosen the sealer.
Pull the old hose out through the bottom and the new hose through.
INSTALLATION
REMOVAL
for front or back
- Move glass panel to the fully closed position.
- Remove sunroof opening trim lace.
- Disconnect the control switch and wire connector.
- Remove headliner
INSTALLATION
- Connect the drain hose to the sunroof housing and test drainage.
- Set headliner into position.
- Connect express module, drive motor, and control switch wire connectors.
- Test sunroof operation, adjust as necessary.
- Finish installing headliner.
- Install sunroof opening trim lace.
- Connect the control switch wire connector. Install control switch
