dual hid setup
Old Jan 22, 2012 | 06:59 PM
xBREWSTERx's Avatar
xBREWSTERx
New Member
Default dual hid setup
i have headlight housings for my stratus the spyder one they take a h1 bulb. my question is can i run on each plug a hid since the stratus has the one blub for brights and dims and they dont make a h1 bi xenon bulb or i havent looked hard enough. can two kits run safely without frying anything or what?
Old Jan 22, 2012 | 07:15 PM
02StratR/T's Avatar
02StratR/T
Are the spyder light projectors? And are they HID compatable? And i dont think they even make a H1 Hi/Lo Bulb at all? The only ones that might work are the HB1. Post a link to the headlights you have please
Old Jan 22, 2012 | 11:55 PM
xBREWSTERx's Avatar
xBREWSTERx
New Member
http://www.spyderauto.com/product.ph...adlights-Black when i got them it said hid compatible
Old Jan 23, 2012 | 09:32 AM
02StratR/T's Avatar
02StratR/T
""- These projector headlights are not compatible with factory Xenon H.I.D. system, it comes with its own standard Halogen light bulbs for installation."" Not HID Compatable sorry:/
Old Feb 3, 2012 | 04:00 PM
smokesxt's Avatar
smokesxt
These housings run a dual h1 bulb. One for lows one for highs. You can run HIDs in the low beams. You cannot run HID in the highs.
It plugs into your factory plug and splits it for the dual bulbs. They are very easy to install and help the light output greatly. I have them on my stratus with 6ks in the low beams, I rarely use the highs.
Old Feb 3, 2012 | 04:04 PM
smokesxt's Avatar
smokesxt
They're not compatible with Factory HID, because our cars run 9007 bulbs factory so they won't install into the housing.
You can put H1 Hids in the low beams (the projectors).
