Head Gasket Replacement 2.5 ?
Old Apr 11, 2012 | 10:52 PM
oeblio's Avatar
oeblio
Default Head Gasket Replacement 2.5 ?
The water pump froze and I had an overheating issue. Replaced water pump and belts. Water pump developed a leak at the block. Re-did water pump with better sealer. Same leak after about an hour of running. I pulled the radiator cap and the coolant had a steady stream of bubbles.
Has anyone done a head gasket on the 2.5? Any advice?
Can the engine be pulled from the top leaving the trans in place?
very unhappy!
