wiper arm
Old Mar 10, 2012 | 11:44 PM
zardoz34's Avatar
zardoz34
Default wiper arm
I have an 05 Stratus. I need to adjust the driver side wiper arm because it is hitting the side of the window when in use. How do I go about doing that?
Old Jul 11, 2012 | 07:24 PM
zardoz34's Avatar
zardoz34
bump bump
Old Jul 11, 2012 | 11:00 PM
deadkenr's Avatar
deadkenr
Typically, there is a nut at the bottom of the wiper arm that holds the arm to the splined shaft. On newer cars, the nut is often covered by a plastic shield. Remove the nut, carefully remove the arm by lifting it upwards off of the splined shaft, reposition the arm 1 or 2 splines, and re-install.
EDIT: The reason I said to remove the arm carefully is because the arm is spring loaded (to hold the wiper blade against the windshield tightly). Sometimes they get pretty well stuck on the shaft and you just need to be careful so that you don't break the windshield.
Old Jul 14, 2012 | 07:52 PM
zardoz34's Avatar
zardoz34
Thanks for the reply. That is what I was kind of thinking but unsure and afraid I might break something. I will give it another look.
