2000 dodge stratus
i have a 2000 dodge stratus it has 108,000 miles on it. i just bought it from a guy for 1200. the car runs but when i drive the car an get up to 45 or higher an i let off the gas the car starts to jerk or sputter. the other day i went to back up an the car cut off but i was able to crank it right back up. i had the gas line replaced bc it was leaking. my husband looked under the car when i push on the break an the break line is leaking. the transmission didnt have alot of transmission fluid in it. an the oil was low. i put oil in the car just to get it by till i get it to a machanic. but does anyone know about how much it would cost to replace the line an is the car sputtering bc of the low transmission fluid? also when i shift the gears the whole motor moves some. i mean everything kinda moves with it. is that normal or is something else wrong?
a brake line should run between 100-150 installed and brakes bled,don't think low transmission fluid(did you put fluid in) is causing your sputtering. the engine will move a little maybe an inch or so when you put in gear or rev the engine,if its excessive check the motor mounts
I would start by draining the trans fluid, and making sure it's the proper kind. I believe the 2.4's used the ATF+4 (the blue bottle from wally world works just fine, no need for the "real" dodge branded atf). Sounds like either wrong trans fluid, or dirty/worn out fluid.
