plz help with car setup
Old Aug 21, 2012 | 11:43 PM
sillyest1's Avatar
sillyest1
Unhappy plz help with car setup
looking for info on how to change caster /camber on a 1996 dodge stratus. i race this car on a 1/3 mile dirt circle track and the right front tire rolls over and i was told changing the camber will help cure this problem
Old Aug 31, 2012 | 08:31 PM
PurpleBeeper's Avatar
PurpleBeeper
Default Camber
Just looking at a suspension photo, I'd say you would back off the jam nut on the end of the axle 1/2 shaft, turn the shaft in/out as desired (there should be a squared off section of the shaft you can get an open-end wrench on) and re-tighten the jam nut.... voila! OR take it to an alignment shop and tell them what specs you want it aligned to.
