2000 Dodge Stratus ES starting & stalling issues
Milage: 123,197 Replaced: Battery, Fuel Pump & Filter Problems: - takes 3, sometimes 4 turns of the key to startposition tostart - after frequent trips cars begins shaking upon starting and when put in drive and accelerated it sometimes bear down and rpms drop and check light flashes while it travels at 5mph and creeps up... - will shake violently, engine will knock and then shut off. - will start up after sitting for awhile butwillsmell like burning gas oroil wen started after started wen it shuts off - has shut off and started back up while traveling at 75mph in the past 1 time. I REALLY NEED HELP!!! got codes that read Cylinder 1, 3 and RANDOM misfire... i dont know the numerical codes but i hope that helps
Sounds like you're due for a tuneup actually.
The rumbling and bogging down, matched with the flashing check engine light, and "random misfires" tells me that your spark plugs and wires are well overdue for a change.
Looking at your engine from the front, the plugs are as follows
1 3 5 (not visible, underneath the "spider" intake)
engine block
2 4 6 (visible and easy to change)
So your "Random misfire 1 3 random" tells me that the left two rear, and to a lesser degree, the other 4 plugs are not firing when they should be.
At that mileage it would also be a good idea to make sure that there is no oil in the spark plug wells, and if there is, than the valve cover gaskets will need changed (pretty simple once you're already getting at the rear spark plugs). The gaskets aren't much at all either.
engine block
