2006 Stratus .. turn key,doesnt crank,makes clicking noise,no dash lights,battery???
Old Oct 1, 2012 | 01:48 AM
Samantha N Mike's Avatar
Samantha N Mike
Exclamation 2006 Stratus .. turn key,doesnt crank,makes clicking noise,no dash lights,battery???
Battery??? dash lights flicker when I turn the key, then go out...
Old Oct 1, 2012 | 06:12 PM
BillS's Avatar
BillS
the battery; are connections clean and tight would be first thing i would check
Old Oct 1, 2012 | 07:05 PM
FrankTA2's Avatar
FrankTA2
If you have a battery tester or volt meter check the voltage at the battery, if not try getting a boost to your battery from another car or charging the battery if you have access to a charger.
Old Oct 1, 2012 | 10:05 PM
Samantha N Mike
Tried jumping it....dash lights lite up like a xmas tree, but still wouldnt turn over..just clicked....and the battery didnt seem to hold a charge. Im going in the morning to check the battery, but have to take tire off first. not sure who the einstein designer was....
never had a problem before...just went out to my car, tried to start it...and the rest is history.
im going to take it to Autozone and have it checked
