Due for transmission flush, is the dealership best place?
My wife's 04' stratus is overdue for a transmission flush. she bought it with 41k miles and it is at 86k. I highly doubt they did anything to the transmission before she bought it. Recently during cold weather the transmission would not switch into drive from a cold start. After a minute or two it eventually engaged.
I figured the transmission is not something you want your local auto shop working on and called up the dealership for service instead. I told them I needed a transmission flush and to make sure they dropped the pan and changed the filter. They charge $235 for the service. I also questions if they would use ATF4 /fully synthetic fluid. They said they use whatever the manufacturer recommends.
I did not speak to an actual mechanic, just the receptionist.
I just don't trust anyone, do you think taking it to someplace like AAMCO would be better than the dealership?
You can pick up a new gasket and filter for just a couple $$ at your local parts store, and the fluid (atf+4 blue bottle at walmart), and a little bit of your time. It's fairly easy to do
Unfortunately, I do not have the time to do this myself. I just bought a house and my time is better spent fixing up the house, not the wife's car.
TNtech, care to elaborate why you are advising against doing what the manufacturer wrote in the owners manual?
Quite the contrary>>>.
Chrysler Group vehicle fluid systems do NOT require regular flushing. These systems
include: engine oil, transmission oil, axle lube, brake fluid, power steering fluid, and
refrigerant. The only exception to this requirement are published in the vehicle
maintenance schedules, e.g. engine coolant. (Coolant...In Maintenance Schedule @ 100K miles/60 months)
Exceptions to this recommendation include only those instances where a failure has
occurred and/or the system has become compromised, contaminated or overheated
beyond the normal operating range.
Chrysler Group does NOT recommend aftermarket chemicals to flush the engine,
transmission, brake or steering systems. Chemicals contained in these products can
damage the system elastomeric components, and contaminate the component fluid,
leading to loss of system/component durability and service life.
Although the manual that I found online states that a flush isn't needed (as noted by tntech), there is a lot of anecdotal evidence that it does help (the pan drop made a heck of a difference in my 41ae [awd version of the 41te strat transmission] transmission Chrysler van).
My apologies, I misread the manual, you are correct it does not say "flush". This is interesting because the dodge dealership I was going to take it to said they were going to flush it. They even explained the process.
I like the idea of taking it to a local shop and providing them with the supplies. Less room for error.
Walmart Brand ATF+4 or should I splurge and get valvoline ATF+4 (full synthetic)?
Is this everything I need to buy? I was thinking like 7 or 8 qts of the fluid to be safe, i can return what I don't use.
http://www.autozone.com/autozone/par...fier=7503_0_0_
http://www.autozone.com/autozone/acc...er=830387_0_0_
Trending Topics
I use the walmart ATF+4 all the time. Mopar actually approved it. I use it in my 02 Stratus and 05 Durango without issues. The stratus has 167k miles on it now.
Unless you live in an apartment complex that frowns on working on your car, I would put the car up on ramps and do the swap yourself. It's not tough at all and takes about an hour or so.
FYI the Stratus takes 4 quarts. If you're in the Vegas area, pm me and I can do it for you or guide you how to do it yourself. Anything over 120.00 for this service is a rip off. The fluid will cost you about 4.72/quart (x4) and the filter/gasket for the pan cost is about 10.00 from Autozone (check Rockauto.com out also).
