2000 dodge stratus, charging light comes and goes
2000 stratus, the batt light comes and goes.. the alt was checked and ok, the batt tested ok, wiring looked ok, so far every thing looks good, charges 14.2 -14.5 volts with the dvom..I know the VR is in the pcm, but would that totaly stop charging/overcharging if the pcm was bad? also will the IAT/map sensor cause the light to go on off? No engine light, or codes, will a batt temp sensor do this as well, anyone have test info?
can a resister be installed to bypass this sensor? does this can have a batt temp sensor?
ty for your input
ty for your input
