Radio issues 2001 Startus R/T
Old Dec 23, 2012 | 03:34 AM
freezingmyfanny's Avatar
freezingmyfanny
Unhappy Radio issues 2001 Startus R/T
Daughter had a fender bender with the car and now radio back lights won't come on. Radio is on but won't change channels. Looks like it shifted in the console (volume **** is bindng against bezel). Any thoughts or suggestions?
Old Dec 27, 2012 | 08:50 AM
ratsttam's Avatar
ratsttam
How bad was the fender bender that it mangled the radio housing?
In all seriousness, if the area the radio sits in is damaged, than the radio itself could well be damaged. I would get the whole vehicle inspected and verify the unibody is intact and straight. If that's all good, than the radio will probably need replaced, I suspect that the housing is bent and damaged the board inside.
Old Dec 30, 2012 | 02:53 AM
freezingmyfanny
Thanks for the reply. The radio is now working The accident was very minor. Apparently the impact jarred the radio and it shifted a bit in the console.I removed the bezel and the faceplate. shifted the radio and it all started working properly. replaced faceplate and bezel...VOILA!! All is right in my daughter's world again.
