rear breaklight assembly. 01 sedan
Old Dec 29, 2012 | 10:10 PM
zach8935's Avatar
zach8935
Default rear breaklight assembly. 01 sedan
Need help. My brakelight is blown on the rear passenger side. I have no clue how to change the bulb.
Old Dec 30, 2012 | 06:12 AM
BillS's Avatar
BillS
this is general info on how to change you may not have to do each step basically have to remove light assembly to change bulb , pull away carpet around brake light inside trunk if needed, there should be 3 or 4 plastic wing nuts(you may have to use pliers to loosen be careful they break sometimes) unscrew nuts, light should pull out from body,then you can access bulbs think most you just twist and pull out
