Stratus Tachometer
Old Dec 31, 2012 | 09:52 AM
CanyousayStratus's Avatar
CanyousayStratus
Default Stratus Tachometer
Hello Everybody -
I have been having some tachometer problems with my Stratus lately.
It is a '98 with 179,600 miles currently, and the tachometer hasn't worked in the last 1000 miles. It is not vital, but I would definitely prefer it if it worked.
Here is a video I made of it -
If you have any solutions, please tell me!
Thanks
Old Dec 31, 2012 | 01:11 PM
BillS's Avatar
BillS
could be a loose wire, but most likely the solder joints are bad(loose) on the circuit board, this was a problem in 1st generation stratus's you can try resoldering the joints check this link out for more info https://dodgeforum.com/forum/1st-gen...er-repair.html or you can by a new cluster from dealer ,a junkyard one will most likely have same problem eventually as yours
