1997 stratus won't rev up and idles rough
Hey guys I have a 1997 dodge stratus. It ran fine for 13000 miles that I've owned it for but now with the 213,000 miles on it I was driving and it started losing power and would bog if I gave it more gas. I cleaned the injectors off but still is doing it. Idles rough and won't rev up. It's a 2.0 5 speed. Any ideas of whats causing this?
Note: it's has happened 3 times. I just run new gas through the line and it runs fine but does it again. The gas is all new and drained. No water in it.
Thanks, Jordon
Thanks, Jordon
Thanks, Jordon
Thanks, Jordon
Pull the plugs out and look for oil on them, and see if they need changed. If you didn't do any "tune up" to it in the past 13000mi, than it's probably time anyways.
Could also be the o2 sensor. Get some codes read and let us know what comes up.
