Problem with Engine
Old Feb 3, 2013 | 03:18 PM
chrismelissa's Avatar
chrismelissa
Default Problem with Engine
I have a 2004 Dodge Stratus with 2.7 liter flex fuel engine. The motor was run without proper amount of oil in it and it caused the number six piston to break where it mounts to the crankshaft. Since then I have replaced the crankshaft, main and rod bearings, and the piston. The car runs well until it gets to normal operating water temperature, then when slowing down to below 1000 rpm's the car will shut off. It will crank right back up but will keep doing this everytime I go to slow down at a stop sign or red light. I have replaced both the crank and cam sensors, the computer and the ecm will no change in performance. If someone knows what is going on with it please let me know what to check.
Old Feb 3, 2013 | 06:09 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Is it setting a P0016 code?
Old Feb 16, 2013 | 04:01 PM
aofarrell2's Avatar
aofarrell2
i dont think this is the right place to post this. should be in the cars tech section.
Posted from Dodgeforum.com App for Android
Old Mar 1, 2013 | 11:28 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Moved to appropriate section. Good Luck
