Oil filter housing broke off
Old Feb 25, 2013 | 12:16 PM
awhitham's Avatar
awhitham
Default Oil filter housing broke off
Hit a huge pot hole lost all oil got under the car today and noticed my whole oil filter and housing are broken off. Is the housing replaceable? I can't seem to find ANYTHING online about this. Please help!
99 Dodge Stratus 2.4L
Old Feb 25, 2013 | 12:58 PM
awhitham's Avatar
awhitham
here is a picture
Attached Thumbnails Oil filter housing broke off-533085_3838071848996_111443739_n.jpg
Old Aug 2, 2020 | 05:58 PM
Audie's Avatar
Audie
Default Same problem curious how you ended up fixing your's
Originally Posted by awhitham
here is a picture
I'm working on my brothers car I believe it's a 97 stratus and same problem I told him I'd try to help him fix it but just curious whether or not I'll have to remove the motor to replace the part or can I leave the motor in and work around everything. I know it's the piece that the pan bolts to I'll have to remove and replace .......
Old Sep 4, 2020 | 05:47 AM
Skidmarkstheguy's Avatar
Skidmarkstheguy
here is a picture
Same thing happened to my 2006 or 2005 stratus it's a 2.4 4 cylinder the oil filter housing seems to be the same spot on mine as well as yours my solution isn't professional by any means but I think could definitely work I decided to take a bolt with the same diameter as the holes and weld them into the tore off oil housing I havent completed my car yet but will definitely let you know what happens
