Fuel pump help needed
Old Feb 28, 2013 | 02:34 PM
kenyanr1's Avatar
kenyanr1
Default Fuel pump help needed
Hi guys. car is a 02 rt stratus. im having trouble getting to my puel pump. under the back seat i have the connections unattatched and the retainer unscrewed. Where do i go from there ? should it pull out ? how is it being held in side ?
Old Feb 28, 2013 | 03:58 PM
kenyanr1's Avatar
kenyanr1
Any suggestions ? Wanna be sure before I start yankin it out
Old Feb 28, 2013 | 04:36 PM
pearl01stratcpe's Avatar
pearl01stratcpe
Just pull straight up. may have to carefully pry it with a screwdriver.
Old Mar 4, 2013 | 03:11 PM
kenyanr1's Avatar
kenyanr1
Thanks for the help pearl01. I got the pump swapped out with a new one. i can hear the pump running but it wont start. the engine sounds like it wants to fire but it doesnt. figured i will swap the filter, see if that works. Is it hard to get to? I read that ill need to drop the tank... Any help is much appreciated.
Old Mar 4, 2013 | 05:22 PM
pearl01stratcpe
Fuel filter? Its part of the pump assembly. You may have another problem.
Old Mar 5, 2013 | 01:34 PM
kenyanr1's Avatar
kenyanr1
I only bought the pump. I believe the filter is sold with the entire assembly, unless im missing something.
