2005 Dodge Stratus Blower Motor REsistor/Module
Old Jun 4, 2013 | 07:09 PM
mxpriefer's Avatar
mxpriefer
Default 2005 Dodge Stratus Blower Motor REsistor/Module
Blower Motor Resistor/Module location please and thanks.
Old Jun 4, 2013 | 08:52 PM
BillS's Avatar
BillS
if its a sedan its on passenger side behind the glove box area next to fan
Old Jun 4, 2013 | 09:03 PM
mxpriefer's Avatar
mxpriefer
Coupe
Old Jun 5, 2013 | 02:19 PM
LeviCoffey's Avatar
LeviCoffey
i'm 99% sure it's the same on the coupe. under/behind the glove box. you have to go from the foot well on the floor. there's a plastic cowling held on by clips, remove that and the resistor is right there. it's a pain to get to if you're a larger person - i had to lay upside down and backwards on the passenger seat, with my head under the dash
Old Jun 6, 2013 | 04:16 PM
mxpriefer's Avatar
mxpriefer
I found it. It's directly behind the glove box, no need to go under the glove box and looks like this image.
Old Jan 30, 2014 | 12:01 PM
eldeana1's Avatar
eldeana1
I replaced the resistor. It had blown out the connector also. Do the connector wires lead to the blower motor? Thanks for your time guys.
Old Jan 30, 2014 | 06:34 PM
BillS's Avatar
BillS
2 wires go to the motor ,2 if you have a coupe go to switch ,3 if you have sedan go to switch not sure which wire goes where no longer have access to any diagrams if you get part from dealer some might print out diagram for you
