06 Stratus crank pulley removal
Old Jun 17, 2013 | 01:31 AM
sharp4084's Avatar
sharp4084
Default 06 Stratus crank pulley removal
Good evening fellow once frustrated mechanics,
I have attempeted to remove my timeing belt, and in this attempt I feel short on removing the crank pulley. I was able to dislodge the pulley but could not entirely remove the pulley itself do to the frame of the vehicle blocking it from complete removal. I lowered the engine with required engine mount removed and still could not clear the frame. What do I do? Am I not removeing a required component to clear the frame?
Thanks future saviors,
Old Jun 17, 2013 | 08:50 AM
Moving this to the Stratus section, Those guys will be able to help you out.
Old Jun 18, 2013 | 01:01 AM
sharp4084's Avatar
sharp4084
Default It is there
Has been going on week two now..aghh, thanks though.
Old Jun 18, 2013 | 11:05 PM
ndtguy's Avatar
ndtguy
Do you have a 2.4DOHC? I had to remove the motor mount on the passenger side of the engine and the one next to the radiator (removed the bolt). Before removing them, I put a jack with a 2x4 on top of it under the oil pan. Once the mounts were unbolted, I just lowered the jack and it was enough to get the pulley out.
I assume you're using a pulley puller?
