1998 dodge stratus overheating
Old Aug 11, 2013 | 06:38 PM
royce555_99's Avatar
royce555_99
Default 1998 dodge stratus overheating
just bought a stratus and it leaks coolant from behind the lower timing belt cover,im gonna get it pressured checked tomorrow,but I think its the water pump, if it is can I use blue devil seal to fix it.
Old Aug 11, 2013 | 07:04 PM
Welcome to DF! Moving this to the correct section.
Old Aug 12, 2013 | 11:02 AM
binky42's Avatar
binky42
Could be water pump and/or thermostat. I needed both replaced a couple of years ago on my 2000.
Old Aug 15, 2013 | 06:09 PM
royce555_99
Default dodge stratus
i replaced thermostat, leaks behind lower timing belt cover.oil looks good no milky colored water so Im thinkin its a bad water pump.i poured blue seal in it but it helped a little but still leaks.the overflow jug gurgles really loud after car is heated up,would a bad water pump cause this. `
Old Aug 16, 2013 | 07:27 AM
ripplegb's Avatar
ripplegb
Default moe info please
Could be your water pump. What engine do you have? If it is your water pump, i have doubts about any type of sealant stopping your leak. If by some chance it would stop it, it would most assuredly be temporary. I just changed my timing belt ,water pump and tensioner in my 06 2.4L. It took about 10 hours and a couple specialty tools. Knowing what i know now i probably could have had it done in about 6.
