01 R/T 3.0 coolant bleeder valve?
Old Feb 7, 2014 | 04:51 AM
Jericho86's Avatar
Jericho86
Default 01 R/T 3.0 coolant bleeder valve?
It doesn't blow hot air while at idle once i get moving and it cycles threw, it warms up..checked fluids that's good,has pressure. i was thinking a possible air pocket in the system? I couldn't find the bleeder valve though,is there one? Give sight to the blind please.
Old Feb 8, 2014 | 01:53 PM
BillS's Avatar
BillS
i think some have a bleeder valve some don't .if you have one it would be at the water outlet where top radiator hose goes into engine should be 3 hoses going into it radiator hose and 2 small hoses and a sensor behind hose, if only 2 hoses and no sensor no bleeder valve. most times when heat doesn't work at idle usually caused by a restriction in heater core or cooling system,weak water pump
Old Feb 10, 2014 | 06:46 AM
pearl01stratcpe's Avatar
pearl01stratcpe
I dont believe there is a bleeder valve on the coupe. Many people have to "burp" the system. Remove the radiator cap, and let the car warm up. Grab the top hose and squeeze, and force any air out that way. Wait until its warm though, and the thermostat is open.
Old Feb 21, 2014 | 05:43 PM
Jericho86's Avatar
Jericho86
Burping it helped thank you
But this new issue among many with this vehicle.
I replaced the distributor core a few months back cause it was shorting out,mis firing,staling & shutting off.
Well with the snow melting, its happened again. I went to buy the book for the elecrical schematics its on order But where is the one place its going to short out at connector,fittings, grounds? Its obviously a electrical shortage because of water im just stumped and will be there all day checking obsolete conections...
Old Feb 22, 2014 | 07:31 AM
pearl01stratcpe
Here is the factory service manual, maybe it will help. http://tearstone.com/2000-2002-eclipse-service-manual/
Scroll down on the page for individual sections.
Old Feb 23, 2014 | 07:42 AM
Jericho86's Avatar
Jericho86
Your the man
