Remove fuses in yellow casing
Old Feb 19, 2014 | 12:41 PM
Nrfidkid's Avatar
Nrfidkid
Default Remove fuses in yellow casing
I have a 2002 dodge stratus r/t and am having an issue that I believe I have tracked to a fuse that is in a yellow casing in the fuse box under the hood. I can't figure out how to remove the fuses in that casing. The casing comes up a bit but won't come all the way out and I can't remove the fuses from inside of it. Any help would be appreciated.
Old Feb 19, 2014 | 12:54 PM
MoparMan1991's Avatar
MoparMan1991
Pictures would be appreciated as well.
Old Feb 19, 2014 | 01:07 PM
Nrfidkid's Avatar
Nrfidkid
Picture attached. I need to remove the fuses in the yellow casing.
Old Feb 19, 2014 | 01:09 PM
MoparMan1991
Can't you just pull them out with a fuse puller?
Old Feb 19, 2014 | 01:20 PM
Nrfidkid's Avatar
Nrfidkid
Not the 2 that are in that yellow casing. All the others yes but that casing prevents you from being able to pull the fuses straight up. I've found others who have posted about how much of a pain it is to remove but no suggestions on how to do it.
Old Feb 19, 2014 | 06:48 PM
MoparMan1991
According to the diagram, what are those fuses for?
Old Feb 19, 2014 | 07:08 PM
BillS's Avatar
BillS
think there for the body control module(radio, power locks, lighting etc ) same as fuse 5 on sedan https://dodgeforum.com/forum/dodge-s...t-working.html
Old Feb 19, 2014 | 07:10 PM
MoparMan1991
Odd. Is there any way to cut the yellow box out or at least open?
Old Feb 19, 2014 | 07:14 PM
BillS's Avatar
BillS
have you tried messing with the plastic between fuse and outside of holder looks like there's a gap on the one side might try pushing it out towards side or down to see if it does anything
Old Feb 20, 2014 | 09:12 AM
Nrfidkid's Avatar
Nrfidkid
I got it out. I ended up taking a pair of pliers and pulling as hard as I can and it came out. Still not sure how to get the fuses out of the plastic without cutting it so I had to replace both of them even though only 1 was bad. Problem solved and that yellow casing is unnecessary. Not sure why it is there to begin with.
