QUICK HELP NEEDED! Torquing Ball Joint on LCA?
Old Mar 2, 2014 | 03:15 PM
bowtieman55's Avatar
bowtieman55
Exclamation QUICK HELP NEEDED! Torquing Ball Joint on LCA?
There's no room for a socket/torque wrench and I've tried a crow's foot; it gets twisted and bound up. I need to get this nut torqued to 55ft/lb. Any suggestions?
Old Mar 2, 2014 | 04:28 PM
BillS's Avatar
BillS
can you get a swivel socket on it, can you turn wheels any might move things enough to get to, when i did mine i just tightened with a wrench til they were as tight as i could get it (don't be the hulk lol) without any problems
Old Mar 2, 2014 | 08:18 PM
bowtieman55
I ended up doing the same thing BillS.
Old Mar 3, 2014 | 12:08 AM
master tech's Avatar
master tech
Site Moderator & Tech
This is what I have done, Use a 21mm box end wrench and put other box end wrench in the open end of the first wrench and torque the nut. You will get at least 100 ft pounds.
