Power Steering Bracket 2.5L
Old Mar 16, 2014 | 06:56 PM
neoncrazy101's Avatar
neoncrazy101
Default Power Steering Bracket 2.5L
Trying to do a timing belt on my 2.5L but I can't seem to get the power steering bracket off. I got all but one (I believe) off but the one I can't get off is on the inside of the bracket closest to the exhaust/abs module. Its in the corner where two sides of the bracket meet and I just can't get it off. I can't seem to get enough room + leverage to remove it. Anyone got any tips on removing the bracket?
Old Mar 16, 2014 | 08:00 PM
BillS's Avatar
BillS
this thread might help for a 2000 model should be samehttps://dodgeforum.com/forum/dodge-s...t-mystery.html especially post #9
Old Mar 16, 2014 | 10:01 PM
neoncrazy101
Alas I'm not sure if that helps or not. Where are the 4 bolts? I removed the two behind the motor (well one and loosened the other). Where are the other two? I'm not sure if I was attempting to remove the correct bolt anymore since in that post it stated that all four bolt heads faced the firewall.
Old Mar 17, 2014 | 02:08 AM
BillS's Avatar
BillS
not very familiar with the 2.5,did you check http://api.viglink.com/api/click?for...erparts.com%2F or here http://www.chryslerpartsdirect.com/ good parts diagrams on both sites, should show diagram of bracket , just enter year, make ,model ,engine ,trim ,and steering
