2001 Straus SE Window/Blower Problem
Old May 26, 2014 | 07:33 PM
matthew34's Avatar
matthew34
Exclamation 2001 Straus SE Window/Blower Problem
Hello Everyone,
Trying to get a little help here so let me start from the beginning. I have a 2001 Dodge Stratus SE with a 2.7L. I kept getting rain water stuck in my back driver side door so i drilled a hole in the bottom of the door to let it drain (Could be unrelated but not sure). A few days after this my battery died to my car (Headlights were not left on but it's possible I left a light on inside the cab). After I charged the battery back up the windows wouldn't work, and blower for the A/C & Heater stopped working, and the Air Bag light came on my control center. I have tested my fuses and they all seem to be fine. Does anybody have any idea what could have caused this issue?
Thanks,
Matt
Old May 27, 2014 | 07:29 PM
BillS's Avatar
BillS
if you already checked both fuse boxes (especially # 5 inside car), try shutting every thing off and unhooking the battery for 10 minutes, rehook battery start car let run for at least 5 minutes without turning anything on ,then check could be body control module got confused (for lack of a better description) .drilling a whole in bottom of door shouldn't cause problems did the same when i had mine
Old May 28, 2014 | 06:24 PM
matthew34's Avatar
matthew34
I just tried that and unfortunately it didn't work. I did also notice my information panel in the middle of the dash also wasn't working (the display that tells the temperature, MPG, , ect.) I don't know if that helps with anything.
Thanks
