HELP!! Loss of RPM
Old Aug 5, 2014 | 09:05 PM
emlee's Avatar
emlee
Default HELP!! Loss of RPM
My 2002 Stratus Coupe is causing me major headaches!! The engine "dies" as the RPMs drop unless I have the AC compressor on!! This sounds backwards to me. I did change out the compressor last year. Could this be the problem?
Old Aug 6, 2014 | 11:18 AM
pearl01stratcpe's Avatar
pearl01stratcpe
I assume the engine light hasnt come on? Could be a number of things; a bad battery ground, bad frame ground, broken vacuum lines, a sensor that got unplugged or is going bad. The battery wasnt unplugged recently was it?
Old Aug 6, 2014 | 12:06 PM
smokesxt's Avatar
smokesxt
Idle sensor/motor will cause issues when engine rpms drop.
Old Aug 7, 2014 | 11:04 AM
emlee's Avatar
emlee
Yes....we did change the battery and also had a hole in the exhaust welded. Problems started after that
Old Aug 7, 2014 | 11:06 AM
emlee's Avatar
emlee
Yes....we did change the battery and also had a hole in the exhaust welded. Problems started after that....
Old Aug 7, 2014 | 11:54 AM
pearl01stratcpe
The ECU has to 'relearn' after the battery is unplugged for some reason. It takes a few miles (estimate 50 or maybe more) to get back to normal. It will run like crap. Unless something didnt get plugged in, and then a code will show. Give it a few days and miles.
Old Aug 7, 2014 | 12:30 PM
smokesxt's Avatar
smokesxt
