2004 Dodge Stratus SE 2.4 SOHC starter
Old Oct 12, 2014 | 02:06 PM
ejn29's Avatar
ejn29
Default 2004 Dodge Stratus SE 2.4 SOHC starter
Turning the key to start does nothing, no clicking, turning over or anything. I'm assuming it's the starter (I have cleaned all battery terminals and connections, if I'm wrong, please let me know), but I can't seem to find the starter at all. The only thing I've found online is someone saying it's right under the air box, but I'm not seeing it. Any help here would be greatly appreciated.
Old Oct 12, 2014 | 05:54 PM
master tech's Avatar
master tech
Site Moderator & Tech
The problem maybe a blown fuse for the ASD relay. This is the most common problem. Check the fuse, I believe its a 20 amp mini fuse. If it blown. Replace the starter and the fuse. If you want to test the circuit. Make a circuit breaker to replace the fuse, because you will be replacing the fuse's. I'm also going to move your post in the stratus section.
Old Oct 13, 2014 | 11:49 AM
pearl01stratcpe's Avatar
pearl01stratcpe
The starter is located in the front of the engine, right underneath the exhaust manifold. Two bolts hold it in, and its best retrieved from below.
Old Oct 13, 2014 | 04:48 PM
ejn29's Avatar
ejn29
I found it. Thanks so much for your help. Is it possible to remove the starter and the heat shield around it out without removing the manifold?
Old Oct 14, 2014 | 11:14 AM
pearl01stratcpe
I believe so. The only time I removed it was when I removed my transmission to replace two bearings, its been too long for me to remember.
