Rough idle and stalling help
Old Jul 7, 2015 | 05:01 PM
pilotforlife's Avatar
pilotforlife
New Member
Default Rough idle and stalling help
Hey guys I have a 2006 dodge stratus 2.4 and its running bad here are the symptoms:
-long crank time
-rough running
-runs at idle but once its above 1000rpm it has to stay there or it will die when it drops to idle
Check engine light is on with no code
let me know what yall think
Old Jul 7, 2015 | 08:31 PM
Gotta be a code if the light is on. How are you reading that? When was your last tune up? How many miles? Things that come to mind, tune up, check/clean throttle body, idle air control and throttle position sensor for starters. Also check for vacuum leaks.
Old Jul 7, 2015 | 11:22 PM
pilotforlife
New Member
Thanks for your response!
Code is P0300 multiple cy misfire
Car has 191k what do you guys think. When it died I was going down the highway and loss power but still running and pulled over
Old Jul 8, 2015 | 10:35 AM
pearl01stratcpe's Avatar
pearl01stratcpe
Sounds like a fuel delivery problem to me. Id check fuel pressure. Could be a bad injector or fuel pump.
