transmission control module 97 stratus
Old Sep 4, 2015 | 07:46 PM
armstrong1984's Avatar
armstrong1984
Exclamation transmission control module 97 stratus
where is the TRM located on a 97 dodge stratus
Old Sep 6, 2015 | 01:21 AM
Douggro's Avatar
Douggro
The TCM is mounted right alongside the fuse panel under the hood. The big wiring connector is held in with an 8mm bolt (if memory serves), and the TCM bracket is held in with two 10mm bolts at the bottom of the bracket.
