2004 Stratus Heater Issue
Old Jan 11, 2016 | 08:13 AM
niss389's Avatar
niss389
Question 2004 Stratus Heater Issue
New to the forum, I have a 2004 Dodge Stratus with the 2.4 DOHC that the heater is acting crazy, heater will not blow out hot air setting at idle, as soon as I drive the car no more than 500 ft. the heater starts putting out hot air. If anyone has some info. on this I sure could use some help on fixing it, with it being cold weather now.
Old Jan 11, 2016 | 09:14 AM
Moved to the correct section, also changed title to a more meaningful thread title.
How is the coolant level? How many miles? Any recent work done? Is this a new problem or has it done it before? The more information you can provide, the better we can assist you.
Old Jan 11, 2016 | 10:28 AM
niss389's Avatar
niss389
Thanks for the reply, stratus has a bit over 99,000 on it, coolant level looks to be a bit low, temp. gauge looks ok, never did have any trouble until last week, no work has been done on it. I tried 2 other heater controls on it but they didn't help any.
Old Jan 11, 2016 | 12:04 PM
If the coolant is "a bit low", that could be an issue if it is low enough.
Old Jan 17, 2016 | 01:51 PM
niss389's Avatar
niss389
Thanks, for telling me about checking the coolant level, it was a bit lower than I first thought, I filled it to the correct level and the header works JUST FINE NOW. Thanks
