Stratus won't start
Old Feb 14, 2016 | 12:30 PM
jeremyjohns's Avatar
jeremyjohns
Default Stratus won't start
I have a 04 stratus sxt 4 door. Friday morning it was very cold and had a rough start, after a few seconds it started running fine. Ran my errands and the car started just fine again, but that night it was even colder, I started it really rough, then the check engine light came on and off twice then it died. Tried starting it again, turns over but won't fire. Once in a while it starts then dies immediately. I'm wondering if the fuel froze in the lines, it was -8 this morning, and was able to get it pushed into the garage. I did the manual key on/off to get the check engine code, but there weren't any problem codes, just says done.
Old Feb 14, 2016 | 01:22 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Does the red dot security light flash when you're not cranking it?
Old Feb 14, 2016 | 05:05 PM
jeremyjohns
No... It stays on for a couple of seconds then goes out.
Old Feb 15, 2016 | 09:30 AM
jeremyjohns
This morning it was a little warmer at 20 degrees, and it seemed like it almost wanted to start. I put in a can of heet yesterday afternoon. The check engine light is on, but still not giving me codes.
Old Feb 15, 2016 | 12:39 PM
TNtech's Avatar
TNtech
If its a crank sensor, about 30 seconds of cranking should set a DTC.
Old Feb 16, 2016 | 03:23 PM
jeremyjohns
First, thank you for all the advice! Its very appreciated. I pulled back the timing belt cover to make sure that was turning. It is, just wanted to make sure. I cranked it for about 30 seconds and still no codes, key on/off, and still just goes to done.. the temps are starting to go up and the snow is finally melting off the car in the garage, I thought for sure that it was going to start, by far the closet it has come. I have a space heater up by the engine compartment now and I'll give it an hour and try again. I'm just baffled why I'm not getting any codes.
Old Feb 16, 2016 | 06:44 PM
TNtech's Avatar
TNtech
Check your fuel pressure next I would think.
