Shaking at 2500 RPM
Old Sep 14, 2018 | 02:42 PM
mavfan72's Avatar
mavfan72
Default Shaking at 2500 RPM
I have a question about how to resolve this new issue with my 2005 Stratus 2.7L v6. The problem is that at exactly 2500 RPM the car starts shaking and will not go higher than 2500 RPM. This happens on every gear. Wasn't sure if this is a known issue with this car. It does have 246000 miles but it seems odd to just happen all of a sudden with normal driving. Thanks
Old Sep 14, 2018 | 02:57 PM
Check engine light on? Transmission ever been serviced?
Old Sep 14, 2018 | 02:59 PM
mavfan72's Avatar
mavfan72
Check engine light is not on and we have not serviced the transmission yet. Only had the car for a few months.
Old Sep 14, 2018 | 03:00 PM
I’d start by catching up on all the required maintenance.
Old Oct 14, 2018 | 06:53 PM
mavfan72's Avatar
mavfan72
Found this video of another guy with the same car having this issue and replaced the Cam Position Sensor and it fixed the issue.
Not an expensive part to give it a try. Anyone else here have the same issue?
Old Oct 14, 2018 | 06:54 PM
mavfan72's Avatar
mavfan72
I found someone else online with the same car that has the same issue. He replaced the Cam Position Sensor and if fixed the problem. Anyone else run into this issue?
