Stratus with an ABS & Brake Lights on
Old Aug 8, 2019 | 12:28 PM
robertg927's Avatar
robertg927
Question Stratus with an ABS & Brake Lights on
Hi,
I'm working on a 2001 Dodge Stratus for a friend of mine. He needs to get the car inspected, but the ABS and Brake lights are on. I first checked the brake fluid which was fine. I then checked the ABS code and got a code 10 - Valve Power Feed Failure (I think that's the phrasing). I've checked the ABS relay/fuse. I believe that my next step would be to check the ABS power connection to make sure there aren't any corroded or loose connections.
Can anyone tell me where is the ABS module located and if I'm on the right track for diagnosing this problem?
