99 stratus won't start
Old Dec 17, 2005 | 09:47 PM
geo097's Avatar
geo097
Default 99 stratus won't start
i have a 99 stratus with a 2.5 v6 ,91000 mi on it the car was running great, then it shut off while i was driving, it restarted after about 20 minutes then i drove about a hour more ,stoped for gas then it would not start had it towed to the shop where the codes said fuel pump and distributor/ignition had them replaced with oem parts (big bucks) got the car back it ran great for about 10-12 miles when i stoped at the mall ,came out and it would not start again ,it crank's like it wants to start, iwaited about 20 mimutes to call a tow truck tryed one more time and it started so i drove it to the shop where it is, they are not getting any codes off the computer for anything being wrong does anyone have any ideas it sounds like a sensor thanks george
Old Dec 18, 2005 | 04:01 AM
brandoncrone's Avatar
brandoncrone
Default RE: 99 stratus won't start
Probably a bad crank sensor.
Old Dec 18, 2005 | 07:50 AM
highrevr/tflea's Avatar
highrevr/tflea
Pull the codes and tell me what is showing....you should have some kind of CEL
Old Dec 18, 2005 | 11:24 AM
thump186's Avatar
thump186
It could be a crank sensor but i would think there would be a code with it. when they looked at it last time did the attemp to recreate the problem or did they just go with the codes? It sounds as though it is something that is acting up when it's hot. If it does it when its been run for a while and then you let it cool for 20 minutes or so and it starts back up and runs good til you shut it off again.
Old Dec 18, 2005 | 03:13 PM
geo097's Avatar
geo097
i just talked to my brother in law he said they orignaly got a P0320 code calling for fuel pump and ignition , they think it a crank sensor or a cam sensor now but he can't find the locations of these sensors they were supposed to talk with a dealer late friday so i won't know till tommorrow if they found the locations thanks george
Old Dec 18, 2005 | 08:35 PM
highrevr/tflea
Well in that case it might not be the fuel pump...Do the Stratus' have Cluster? Anyhow the fuel pump could be giving...I would try that... the codes will show for all usually what is going. My neon did the same thing when it got hot. My gas gauge didnt work, I let it run out of gas a few times and it finally went out. Some ppl take the whole fuel pump mod out and just clean the in-tank filter but Id just replace the whole thing. Go w/ walbro cheaper then stockpump if they make em for the STRAT
Old Dec 19, 2005 | 10:08 AM
brandoncrone
p0320 is no crank reference signal at PCM. You need a crank sensor. Also for reference, the PCM does not always set a code for an absent crank or cam signal. Usually the only way it sets that code is when it cuts out while the engine is running.
Old Dec 19, 2005 | 10:39 AM
highrevr/tflea
ewww...perhaps they got the code wrong...if it reference what crone says then you definately need crank sensor...
Yup went through my codebook and p0320 is crank position sensor...REFERENCE
Old Dec 19, 2005 | 11:20 AM
geo097's Avatar
geo097
thanks for the info it sounds like i should have come here first do you know the location of the crank sensor so i can tell them where it is or maybe i should pick up the car and put it in myself if its not to hard thanks again, george
