2001 Stratus HVAC Climate Control Recalibration Recalibrate Blend Door Mode Actuator
Old Dec 26, 2020 | 08:19 PM
boiboi365's Avatar
boiboi365
Default 2001 Stratus HVAC Climate Control Recalibration Recalibrate Blend Door Mode Actuator
Hello,
This has been posted in the forum before but I had trouble finding it this time around. Thought I would repost with various keywords in the title to make it easier to find.
PROBLEM1: Air/vent position randomly changes or doesnt change at all. Blows from windshield defogger vent or to feet etc.
PROBLEM2: Air randomly stops blowing cold OR heat randomly stops blowing hot. This happened to me regardless of driving condition, gear, etc...totally random even after doing a thorough and complete coolant drain/flush/air purge.
SOLUTION: Recalibrate the HVAC climate control blend door mode door actuators.
NOTES:
- I tried this without pulling the fuse and it didnt work
-Car was completely cold overnight
1. Pull the fuse (left side of driverside dash. open door to see it). Its the fuse with the black connector making it easier to pull.
2. Push fuse back in (for me I only waited maybe 30 seconds)
3. Move vent power to number '2'
4. Move temp mixture to far left (coldest)
5. Move vent position to far right (defogger)
6. Start car
7. Press and hold rear defroster button for a few seconds (circle to right of vent position ****)
8. You should hear chime and see AC00 show on dash
9. Listen underneath the dash near the floorboards for the blend/mode doors moving
10. Wait until AC00 goes away
11. Get mad if this still doesnt fix it (such is car repair!)
Defrost Defroster Defog Defogger EBL AC00 actuator mode door blend door HVAC climate control climate controls heat heater heating AC A/C air cold colder blowing blower fuse fuses reset recalibrate recalibration
Old Dec 31, 2020 | 10:22 AM
UnrecognizedObscurity's Avatar
Sorry. Wrong thread.
Last edited by UnrecognizedObscurity; Dec 31, 2020 at 10:26 AM. Reason: Posted in wrong thread...
Old Aug 28, 2024 | 09:34 PM
MONKEY_BRAIN's Avatar
MONKEY_BRAIN
Hi, thanks so much for your post! It seemed to work for a bit when I tried it, but then it started switching vents again. My question is, in the step to "start car", do I need to just turn it on to the battery or turn the engine on?
thank you so much.
Old Aug 30, 2024 | 10:26 AM
boiboi365's Avatar
boiboi365
Turn the car on (engine on).
Old Aug 30, 2024 | 12:40 PM
MONKEY_BRAIN
Awesome, thank you so much.
it keeps like, going back to shifting vents after I do this.
even with turning the engine on. (I tried it both ways)
I'm going to try it first thing before I turn the car on. (Having left it cold all night). Because I keep forgetting that step.
If that doesn't work, I'll be back.
Thanks.
