Oil Leak Above Pan - 99 Dodge Stratus 2.4L DOHC
Trying to fix oil leak(s) on my 99 stratus, and saw some dripping off a bolt that's above my oil pan and directly below what appears to be a green electrical/sensor connector. Seems like the bolt itself is securing a shield above the green connector, but oil is definitely pooling on that bolt. I've done some digging online and can't find any info about either the connection or the bolt, any idea what I might be looking at here?
The picture below shows what I'm talking about. The pan in the foreground (to the left) is the oil pan...I think the pan gasket is leaking too, you can kind of see the green dye around the edges from the kit I used. Thanks all.
