noise noise noise
Old Mar 17, 2006 | 02:24 PM
Johnstratus's Avatar
Johnstratus
Default noise noise noise
a strenge noise came from the steering wheel while driving, like a bird is chirping, any idea?
Old Mar 17, 2006 | 04:55 PM
DevilsReject's Avatar
DevilsReject
Noob Assassin
Default RE: noise noise noise
Check your power steering fluid level and try to duplicate when the problem is indeed happening. Does it happen only on really hard right/left turns? Or simply everytime you turn the wheels?
Old Mar 17, 2006 | 05:18 PM
Johnstratus
thank you for your reply. the noise happends all the time, not because of turning. the fluid is at the max level
Old Mar 17, 2006 | 05:41 PM
DevilsReject
Noob Assassin
Well, then my suggestion would be to check your CV Joints and your power steering. There's a good chance that the power steering pump could be failing/going out.
Does the car ever seem to take longer to turn when turning the wheel?
Old Mar 17, 2006 | 05:46 PM
Johnstratus
thanks. seems nothing change about the driving. just wondering if it is necessary to take the car to the dealer.
Old Mar 17, 2006 | 05:49 PM
Johnstratus
by the way, i do find some red oil leaking under the car, but the oil level is still at max
Old Mar 17, 2006 | 05:52 PM
DevilsReject
Noob Assassin
oooooo that's not oil there bud..... that's one of usually 2 things......radiator fluid or transmission fluid. It's almost always tranny fluid though.
I'd get your car into a shop fast and pay the $50 or so to have em look your car over.....the last thing you want is to have that kind of problem on the road. I had the seal on my transmission pan go....and it leaked some....and had I not fixed it could have been a big deal. Even still, I caught it early and it was still $400.
Old Mar 17, 2006 | 05:57 PM
Johnstratus
thanks bud, well done. i will let you know once i have my car checked
