2001 Dodge Stratus 4dr SE
Old Apr 2, 2006 | 06:06 PM
michella1969's Avatar
michella1969
Default 2001 Dodge Stratus 4dr SE
My check engine light had been coming on and off, finally it just stayed on. I took it to have a diagonstic test, it came back with a code of P0601. Can some one explain this code to me, as well as tell me what needs to be done to fix it.
Old Apr 4, 2006 | 03:32 PM
mkbruin's Avatar
mkbruin
Default RE: 2001 Dodge Stratus 4dr SE
Internal Control Module Memory Check Sum Error
It sounds like your ECU is developing a fault. First, pull the negative battery cable and let it sit for about 10-20 minutes. This will reset the computer. If you are still gettign the error, you may need a new ECU.
Old Apr 29, 2006 | 02:31 PM
slick_stratus's Avatar
slick_stratus
hey im not gitting that check engine code but i am gitting many others....!!!! my map, maf,and tps, sensors are reading corralation at load.. and im gitting a high circut bank one sensor one error. i dont know what to do. i have replaced the map,map,and tps sensors and the check engin light never went off.. this is where it all started--------------------> i took off the cat converter and the car ran fine. ok. well about a week later i took off the throttlebody and bored it out but before i did that i undid my battery to reset the comp. i bored it out then hooked it back up. then the problems began. thats when i replaced all of that ****.... then i went and got 2 new o2 sensors check engin light still on! i went and got a dio done again i was gitting low circut bank 2 sensor 2 i know this wont make sence but hear me out. high circut bank2 sensor 2 ...... yeah.. so i bought a o2 simulator to simulate the cat converter to try to solve the problem and i got another dio done. i must of got like 25 dio's done by now... and i was reading low circut bank2 circut 2 so i fixed that and again went and got another dio done and now im gitting map, maf,and tps, sensors are reading corralation at load.. and im gitting a high circut bank one sensor one error and the car's rpm's wont let me go past 3500.. it bounces like the governor is stoping it when im swithching it from 1st to 2nd to 3rd and so on and when i stop or stay stedy on gas it bounces at 1000 rpms. and when on stoped it will try to cut out almost stalling then catch its self BOY IS THIS CAR PISSING ME OFF. PLEASE HELP CUZ PEOPLE IVE WENT TO DONT KNOW **** ABOUT MODDING CARS AND TELL ME WHAT I KNOW IT IS NOT....................SORRY IF THIS IS A REPEAT FOURM U HAVE SEEN ALOT OF BUT I NEED MAJOR HELP BAD IM RUNNING LOW ON IDEALS!!!1
