Fan blower question
Old May 15, 2006 | 03:15 PM
JamesThurber's Avatar
JamesThurber
Default Fan blower question
I am new here and wanted to know if anyone had any suggestions before I take it to the dealer. All of a sudden the fan for ac/heat will not blow unless it is turned to the highest setting. I thought it might be a fuse but I checked those and it was running so I didn't think that it would be that and it wasn't. I have a 2000 Stratus ES with 2.5L engine. Any suggestions would be greatly appreciated.
James
Old May 17, 2006 | 02:20 PM
daninthemoon's Avatar
daninthemoon
Default RE: Fan blower question
I have the exact same problem and am thinking about replacing the heater/ac control assy. I'm hoping you get a better answer here, because I'm hoping for a cheaper fix.
Old May 17, 2006 | 02:27 PM
daninthemoon
Check out the post and replies for JeremyBillie re blower motor/resistor
Old May 17, 2006 | 05:06 PM
daninthemoon
I just replaced the blower motor resistor and my problem is fixed. It's under the glove box, as described in the jeremybillie thread. Cost $27 from the dealer. Now I just gotta wait and see if the blower motor itself is also a problem, again as described in the mentioned thread. good luck
Old May 18, 2006 | 01:14 AM
John_E's Avatar
John_E
What year is your Stratus? I just went through the same thing on my 2003, for which there is a Technical Service Bulletin describing how to replace the OEM flat metal resistor pack with a more robust-looking, thicker unit. In this case, I do not think the motor itself is to blame; I suspect the original made-in-Mexico resistor packs were too wimpy to handle the current. Anyway, the new one works like a champ, and the only trick was having to cut away the plastic shelf on the mounting bracket.
Old May 19, 2006 | 02:00 PM
tomthedog's Avatar
tomthedog
had the same problem in my 02 stratus. took it to the dealer, they replaced a relay. cost about 1/2 hr labor + $12 for the relay. works fine now. have read at other sites that the fan on the way out may cause the relay to blow. hope this helps.
