Tachometer and Odometer Problems
Old Jul 24, 2006 | 05:48 PM
dracc's Avatar
dracc
Default Tachometer and Odometer Problems
I have a 1997 Dodge Stratus. The tachometer and odometer comes on and off. I was wondering have any of you had a simuliar probem? And if so how did you correct it? Any information would be helpfull? Thanks
Old Jul 24, 2006 | 07:21 PM
kang25's Avatar
kang25
Default RE: Tachometer and Odometer Problems
sounds like a shorting ground or possibly a fuze or connection somewhere in the wireing, could be really easy to spot or could be really involved. I know that doesn't really help, just figured I'd offer up my .02
Old Jul 29, 2006 | 02:24 PM
dracc's Avatar
dracc
thanks anyway, I guess I really need to get a wiring schematic and get down to the nitty gritty.
Old Aug 16, 2006 | 02:27 AM
Tarbbrat's Avatar
Tarbbrat
Did you ever figure out the Tachometer odometer problem? I have a 96' 2.4L with the same problem
Old Aug 16, 2006 | 02:13 PM
dracc's Avatar
dracc
Haven't figured it out yet. I currently in the middle of replaceing the rack and pinion. The tach and odometer is actually my next project. I'll let you know when I figure it out.
Old Aug 17, 2006 | 03:20 PM
Losingtrustindodge's Avatar
Losingtrustindodge
New Member
Try this out http://www.automotiveforums.com/vbul...d.php?t=133083 its in the instrument cluster and after time a cold solder joint comes loose.
