AEM Tru-Power Pulley Kit Dodge Stratus RT 01-03 3.0L V6 question
have you tried jacking up the front end, and with the tires on, shaking down the front end?
when sitting still and applying torque to the chassis, can you do it, or only when moving?
i dont think its wheel bearing, i do know my passanger side bearing is at the beginning stages of going away. its so wierd. i can even hear this click backing out of my driveway real slow. the brakes, front end is all tight, im going to take my drivers strut off this weekend and check it out. il know as soon as i see it lose. its pouring rain where i live so i have to wait. now when you said applying tourqu when im sitting still, you mean just put in gear with the brakes on right? i actualy have heard this noise when i do that too. especially when its cold and the motor is reving and full of tourque. im bout to bring it back to mechanic again anyways, need my back plugs changed, i dont feel like tearing the top of that motor off to get to them.
if you can do it when sitting still, and when you hit bumps, it sure sounds like when my mounts went...my front mount came out in pieces...thats how bad it was.
i also had some noises in the brakes before changing to the new brakes.
