changing battery
Old Aug 28, 2006 | 04:40 PM
tommyboy's Avatar
tommyboy
Default changing battery
I have a 01 stratus r/t and had a battery go bad after 2 years! I replaced the battary and now it will run fine but when i stop the car dies! Is there a computer reset procedure? Please help!!
Old Aug 28, 2006 | 05:35 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
Default RE: changing battery
my battery went bad late last year...but i didnt have any problems afterwards...any check engine light?
Old Aug 28, 2006 | 05:42 PM
tommyboy's Avatar
tommyboy
yes, autozone told me it was an o2 sensor and shouldn't hurt much of anything. someone told me that i need to put car in Neurtral and set a 2k rpm's for almost 10 minutes for the computer to reset. Does that make sense to you?
Old Aug 28, 2006 | 07:24 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
ive never heard that...my battery was dead for three or four months, and i didnt have to reset anything.
Old Aug 30, 2006 | 09:30 AM
tomthedog's Avatar
tomthedog
have charging sys checked. it may be overcharging the batt and frying it. it MAY be just a bad batt, i've had 1 or 2 right off the shelf. they work okay when they want to, just not all the time. if the warrenty is still good take that puppy back, change it out and see whats up.
the charging sys SHOULD run at about 13.5-14 volts right after starting. after a min or2 it should drop down to about 12.5-13v. when cranking the batt shouldn't drop below 10v(means its not holding a charge).
to me it sound like the pcm/ignition needs more power. if batt is ok look for bad wires. good luck.
