????ideas????
Old Sep 3, 2006 | 09:57 PM
inkedokie's Avatar
inkedokie
Default ????ideas????
changed pads almost 2 weeks ago NEW Prob.. some one said rotor some caliper got a new noise Screeeeech and Griind any ideas got about 60000 o3 any help greatful thanks
Old Sep 5, 2006 | 10:53 PM
SilverStratus06's Avatar
SilverStratus06
Default RE: ????ideas????
when i first put my drilled slotted rotors and new pads on it made that noise once or twice so my guess would be the caliper
Old Sep 6, 2006 | 11:24 AM
tomthedog's Avatar
tomthedog
some semi-metalic pads have a bigger than norm piece of metal on the surface of the pad. this can cause a squeeeek. also, if you did not lube the area between the pad and piston you can get some ood sounds too. pull the wheels off and double check the bolts to make sure the calipers aren't comming loose, as that is waaay bad. it just happened to a friend this past weekend. he got lucky, lived, and didn't total his car. good luck.
