blowing Fuse #8 (Ignition Fuel Starter)
Old Sep 19, 2006 | 12:20 AM
tanya_alina's Avatar
tanya_alina
Default blowing Fuse #8 (Ignition Fuel Starter)
When I put another fuse and try to crank the engine it keeps on clicking. I took it to the dealer and they had all the electronics checked. It was all fine. They also couldn't reproduce the same problem even thought I had blown about 20 fuses in the last 2-3 weeks.
Old Sep 19, 2006 | 06:00 AM
tomthedog's Avatar
tomthedog
Default RE: blowing Fuse #8 (Ignition Fuel Starter)
is it still blowing fuses? might have been a loose connection.
Old Oct 12, 2006 | 12:00 AM
Jesse R.Medellin's Avatar
Jesse R.Medellin
I'm having the same problem with a 2000 Startus 2.0L. I believe it might be the key switch
Old Oct 12, 2006 | 01:19 AM
chaser's Avatar
chaser
You could allways go with a slightly higher fuse!! I havent messed with ignition fuses but ive used a 40 instead of a 30 for an AMP because the AMP keep blowing the 30's the 40's lasted longer until some one decided to remove to cover for it to be cooled and 1 never put it back on and 2 set the screws/screwdriver in it. The next day when the AMP waqs turned on the screwws wernt spotted but the screwdriver was wede stick fuses in and they would literaly desenegrate ywe couldnt figure it out saw the 2 big screws adn were like their we go then next fuse and spake 2 half inch screws layed acriss the positive and negavite lines and arched and blew the AMP. But yea try a larger fuse!! I dont think it hurts as far as i know a slightly larger fuse could do better then a smaller one if the smaller ones are going to fast.
